Choosing the Right Compressor for Low Pressure Steam Applications
  • Thread starter Thread starter ericksonla
    Pump Steam
In low pressure steam applications at lab scale, suitable compressors include liquid ring vacuum pumps and rotary vane vacuum pumps, with a recommendation for a secondary heat exchanger to condense steam before it enters the pump to avoid cavitation. Mechanical vapor compression systems, like those used in desalination, typically employ centrifugal compressors, though they may not scale down effectively for smaller applications. Users should consider the material of the compressor, avoiding cast iron or plastic, and explore whether compressors designed for refrigerants like R134a can be adapted for steam. The desired specifications include an inlet of 9 psi at 100°C and an outlet of 15 psi, with a flow rate of 100 CFM. Recommendations for suppliers of low pressure steam compressors are sought within the discussion.
ericksonla
Does anyone know what types of compressors/vacuum pumps can be used with low pressure steam at lab scale?
I'm interested in a mechanical vapor compression system like this one used for large scale desalination and industrial processes. I think these use centrifugal compressors but I know those don't scale down well.
For a ballpark sense of scale, I think the process would need something like:
inlet : 9 psi/0.6 bar, 100°C
outlet: 15 psi/1 bar, whatever superheated temp comes out
flow rate: 100 CFM
In the big picture, what characteristics make a compressor suitable for steam? eg, I suspect I should avoid cast iron or plastic but could I just use any compressor that was designed for R134a and fits the other requirements?
Hi ericksonla, this topic is of interest to me. Presently, I am preparing to carry-out some experiments with low pressure steam in a lab-scale air-cooled condenser. I have the option of using a liquid ring vacuum pump or a rotary vane vacuum pump. I am not sure which one is more suitable so I would be interested to hear what others recommend on this thread. However, one thing I have learned from experience with steam is that some sort of secondary heat exchanger should be present upstream of the vacuum pump to condense steam that is about to enter the pump. Condensing the steam at this point prevents it entering the pump which could otherwise lead to issues such as cavitation. I am not sure of your set-up so maybe you don't need something like this.
Can anybody here give me names of suppliers of low pressure steam compressor? I need a steam compressor or steam compressor system that can compress low pressure (2.56 kPa) to 1 bar and above?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
