Jesse2789
- 4
Find the mass, M, of a rotating wheel of radius r that has an attached mass, m, suspended by a string using conservation of energy. The mass is suspended a height, h, above the ground and it takes a time of t seconds to reach the ground.
U_g,mass = K_f,mass + K_f,wheel
mgh = 1/2(m_b)(v_f)^2 + 1/2(Iω_f^2) (m_b is the hanging block's mass)
I_(disk) = 1/2(Mr^2)
a_y,block = (-2h)/(t^2)
v_f,y,block = (a_y,block)*t
^At this point the only two unknowns in the conservation equation are I and ω. To find ω_f could I just say that v_f,y,block is the same as the final tangential velocity of the wheel?
So then it would just be ω_f=v_t/r, then you could find M through I=Mr^2?
EDIT: I just tried this with numbers and came out to an unreasonably high mass of 1879kg. I did this in lab and could lift the wheel, so obviously there's an error somewhere in my reasoning.
