Use exact arithmetic to solve the following system?
  • Thread starter Thread starter Math10
    Arithmetic System
Math10
Use exact arithmetic to solve the following system:
10-3x-y=1,
x+y=0.
I know that 10-3=0.001.
Here's the work:
y=-x
10-3x+x=1
x(10-3+1)=1
x=1/(0.001+1)=1/1.001
y=-1/1.001 since y=-x
The answer for this problem is (1/1.001, -1/1.001) but this is a Linear Algebra problem. The work that I've shown above are Algebra 1 skills. I must use exact arithmetic to solve the system. How do I do so?
10-3x-y=1,
x+y=0.
Here's the work:
y=-x
10-3x+x=1
x(10-3+1)=1
Do NOT use decimal; use exact fractions instead. Your original equations are
\frac{x}{1000} - y = 1 \\<br /> x + y = 0
So, of course, you have
\frac{x}{1000} + x = 1 \: \Longrightarrow \left( \frac{1}{1000} + 1 \right) x = 1
Surely you can finish this!
Frankly, I don't see any problem with using 1.001. That's every bit exact as \frac{1001}{1000}.
If you had written something like 0.3333 for 1/3, then you would not be using "exact arithmetic".
I was trying to offer advice that would apply to any, general system, not just to the very special (and very simple) example case illustrated in the problem.
Is that the right way to use exact arithmetic to solve the system? No augmented matrix and Gauss-Jordan method involved?
No, you can use whatever method you want (Gaussian elimination, for example); it is just that instead of using decimal numbers in the procedure you use rationals throughout. For example, consider the system
6 x + 8 y = 19\\<br /> 15 x - 9y = 12
The augmented form is
\begin{array}{rr|r}<br /> 6 &amp; 8 &amp; 19\\<br /> 15 &amp; -9 &amp; 12<br /> \end{array}
After one stop of Gaussian elimination we have
\begin{array}{rr|r}<br /> 6 &amp; 8 &amp; 19\\<br /> 0 &amp; -29 &amp; -71/2<br /> \end{array}
Thus,
0 x - 29 y = -71/2 \: \Longrightarrow y = (-71/2)/(-29) = 71/58. Also,
x = (1/6)[19 - 8y] \; \Longrightarrow x = (1/6)[19 - 8(71/58)] = 89/58.
What do you mean to use rationals? Do you meant that I convert 10^-3 into a fraction?
So I set up the augmented matrix and I want to solve this system using Gauss-Jordan method.
1/1000 -1
1 1
Is this how I solve this problem with 1 and 0 after the straight line in the right?
1/1000 -1
1 1
Do you know the matrix method? If so, use it to solve it with those numbers.
