How to Find Potential Functions? A 10 Minute Introduction
To find a potential function for a given vector field ##\vec F(x,y,z)##, it is necessary that the curl of the field equals zero, indicated by the equation ##\nabla \times \vec F = \vec 0##. The potential function ##\phi## can be derived from the vector field by ensuring that the gradient of ##\phi## matches the components of ##\vec F##, expressed as ##\nabla \phi = \vec F##. This involves integrating each component of the vector field to recover the potential function. An example illustrates this process with specific functions, demonstrating the integration of each component to find ##\phi##. Understanding these principles is essential for solving related mathematical problems effectively.
Definition/Summary
Given a vector field ##\vec F(x,y,z)## that has a potential function, how do you find it?
Equations
$$\nabla \phi(x,y,z) = \vec F(x,y,z)$$ $$\nabla \times \vec F(x,y,z) = \vec 0$$
Extended explanation
Suppose we are given a vector field ##\vec F(x,y,z)=\langle f(x,y,z),g(x,y,z),h(x,y,z)\rangle## that has a potential function ##\phi## and we wish to recover the potential function. We know that we must have##\nabla \phi =\vec F##, so ##\phi_x = f,\, \phi_y=g,\, \phi_z = h##. This means we can recover ##\phi## by integrating the components of ##\vec F##.
To look at a particular example, consider $$\vec F =\langle 2xz^3+e^z,-z\sin(yz),3x^2z^2-y\sin(yz)+xe^z\rangle$$Our unknown potential function ##\phi## must satisfy$$\phi_x=2xz^3+e^z,\, \phi_y=-z\sin(yz),\,\phi_z=3x^2z^2-y\sin(yz)+xe^z$$Students often solve this type of problem by taking the anti-partial derivative of each equation:$$\phi = \int 2xz^3+e^z\,\partial x = x^2z^3+xe^z$$ $$\phi = \int -z\sin(yz)\...
Continue reading...
Mathematics news on Phys.org
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
