Flap deflection angle of a wing on lift to drag ratio?
The flap deflection angle significantly impacts the lift to drag ratio of a wing, with extended flaps increasing lift but also substantially increasing drag. This results in a decreased lift to drag ratio, which is particularly relevant during landing and takeoff phases. Flaps enable wings to produce more lift at lower speeds, enhancing aircraft performance in these critical phases. Additionally, they can improve ground effect, especially in low-wing aircraft. Understanding this relationship is crucial for optimizing flight efficiency.
barca12345
How does the flap angle affect lift to drag ratio of a wing?
As flaps are extended, the wings will generate more lift and much more drag. The lift to drag ratio goes way down.
As you may know, flaps are used primarily during the landing sequence and sometimes on takeoff as well. They allow the wings to generate more lift at slower speeds. They can also enhance ground effect, especially on low-wing planes.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
