0.5V across 1.5m tungsten wire w/cross-sect. area 0.6 mm^2 - Find wire current
A homework problem involves calculating the current through a 1.5-meter tungsten wire with a cross-sectional area of 0.6 mm² and a voltage of 0.5 volts. The resistivity of tungsten is given as 5.6E-8 ohm meters. The initial calculation for current yielded an incorrect value due to not converting the area from mm² to m², which is necessary for accurate results. After correcting the area conversion, the current was found to be approximately 3.57 amps. The discussion highlights the importance of unit conversion in physics calculations.
student_fun
0.5 volts is maintained across a 1.5 meter tungsten wire that has a cross-sectional area of 0.6 mm2. What is the current in the wire?
Resistivity of tungsten: 5.6E-8 ohm meters.
Current Density: J = \sigma \cdot \frac{V}{l}, J = \frac{I}{A}
Definition of resistivity: \rho = \frac{1}{\sigma}
Variable meanings in equations used:
I: current in amps, A: cross-sectional area of wire in m2, \sigma: material conductivity, V: volts, l: length of extruded cross-sectional area (in this case, a wire) in meters, \rho: resistivity in ohm meters
Using the relations and data available it seems to make sense to find the current in the wire by relating the known tungsten resistivity to the two definitions of current density in which most variables are known except for the I (current) that I'm after. Doing this yields:
\frac{I}{A} = \sigma\frac{V}{l}
\sigma = \frac{1}{\rho}
\frac{I}{A} = \frac{1}{\rho} \cdot \frac{V}{l}
I = A\left[\frac{1}{\rho} \cdot \frac{V}{l}\right]
Then I plug and chug:
I = 0.6\left[\frac{1}{5.6E-8} \cdot \frac{0.5}{1.5}\right] = 3571428.571 Amps
However this answer is not valid. Can anyone see something I am doing that is outright wrong? Invalid logic somewhere?
Any hints to get me on the right track would be greatly appreciated.
Thank you for your time.
Your answer has the right procedure but the area is in mm^2 you need to convert it to m^2. So you are off by a factor of 10^6 meaning 3.57 amps.
Below is an easier way to go about the problem and attain the same answer.
resistance = (resistivity*length)/cross sectional area in m^2
Current = voltage/ resistance
Nevermind, lol, solved my own problem. Found out that I didn't convert millimeters squared to meters squared. Got it right now :)
Thanks for the reply fball558 :) It's nice to get other views while your pourin over pages and pages of physics :)
