1 pulley, 2 masses, 2 inclines
  • Thread starter Thread starter TheronSimon
    Pulley
To calculate the tension in the cable connecting two masses on different inclined planes, it's essential to analyze each mass separately using Free Body Diagrams (FBD). The forces acting on each mass include their weight components along the incline and the tension in the cable. The tension should be the same on both sides of the pulley, and the acceleration of the system must be considered, as it is influenced by the different masses and angles of inclination. It's crucial to avoid assumptions that the values are independent of mass, as this can lead to incorrect conclusions. By applying Newton's laws and identifying the constraints of motion along the inclines, the correct tension can be determined.
TheronSimon
Calculate the tension in the cable connecting the two masses. Assume all surfaces are frictionless.
in lieu of the picture here are the given specs:
on the left side a 5 kg mass with a 60' incline
on the right side a 6 kg mass with a 70'incline
a=Fgsinθ
Fnet = ma
my attempt was to calculate both sides for acceleration since its frictionless both would be non dependant on the weight of the mass
then i used
Fnet=ma
so Ft-Fg = ma
and after the math Ft = 41.45 and for the right side Ft= 114.66 but its the wrong answer so how do i complete this question?
that is not true when you have diffferent inclines with the masses connected by a cable
then i used
Fnet=ma
you have to look at each mass separately using a free body diagram to identify the forces acting along the incline and apply Newton 2 to each mass separately
so Ft-Fg = ma
the tension force on each block is Ft directed along the incline and pulling away from the mass you are examining. But the gravity force along the incline is a component of Fg.
Note when you redo this problem that the tension in a cable wrapped around an ideal pulley is the same on both sides of the pulley.
Im still lost :S
As mentioned by PhanthomJay,
the only analytical approach is to draw a Free Body Diagram(FBD) of both bodies and the string and identifying the constraints.
Guessing that the values shouldn't depend on mass, is risky and should be avoided at all costs.
When you draw the FBD of blocks, forces acting on them are their weight components parallel and perpendicular to incline.The normal reaction exerted by inclines and the tension force exerted by chord.
Now you draw the FBD of string which will help you corelate the tension forces exerted by strings on both bodies.(What is it? How does the mass of string affect this relation?)
Finally you identify the constraints.The only possible movement can be parallel to the inclined surfaces (body 1 will move parallel to incline 1, body 2 will move parallel to incline 2)and at all times no motion takes place perpendicular to the incline(body 1 has no motion perpendicular to incline 1 and body 2 has no motion perpendicular to incline 2).
Plug in the values.
Apply Netwons 2nd and Third Law relating action reaction forces.
What do you see?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
