RabbitWho said:
u= distance from the object to the mirror
v = distance from the image to the mirror
f = focal length
If the image is real 1/u + 1 v = 1/f
If the image is virtual 1/u - 1/v = 1/f
I don't understand what they are talking about and I would like to
I'm not sure what your problem is here, except that in your example you seem confused about where to take the measurements from.
All measurements are from the centre of the mirror (surface) on the optical axis.
u is the magnitude (*) of the distance from the centre of the mirror surface to the object.
v is the magnitude (*) of the distance from the centre of the mirror surface to the image.
f is the distance from the centre of the mirror surface to the focal point, where rays parallel to the principle axis meet (for concave mirror) and where they appear to come from for a convex mirror. f is given a positive value for a cocave mirror and a negative value for a convex mirror.
(*) your formulae seem to imply that u and v are always positive, hence I say magnitude. But how your formulae handle virtual objects and virtual focal lengths, I'm not sure.
I've never come across this changing the formulae for different cases, I always use 1/u + 1/v = 1/f for all objects, all images and both types of mirror or lens. In that case, u, v and f need to take positive and negative values according to some strict convention. (Just as distances up and down need to be +ve and -ve, for example.) I've always used the convention that anything real is given a positive value and anything virtual is given a negative value, but there are other conventions.
I watched some videos to figure out what they meant by focal length ...So focal length is the distance between the focus and the mirror.
Yes
It's how far away from the mirror you have to move an object in order for it to be in focus, whether that be a real in focus image or a virtual one, right?
No. An object can form an image and be "in focus" at any distance.
The focus refers specifically to where rays parallel to the principal axis meet after reflection or refraction (or in the case of a divergent mirror or lens, the point such rays appear to emanate from.) You can find this using a distant object (Ideally at infinity! So stars or the sun would be a good approximation, but a light 50m away would be reasonable for the sort of experiments you might do.)
So right now I have my book and there is a mirror 1m away from me. I hold up the book and it is 2m from its virtual image.
1/u - 1/v = 1/f
1m - 1m = 0?
Isn't the answer always 0? but that can't be because the focal length isn't always 0.
You appear to be using a plane mirror, if the real object is 1m in front of the mirror and the virtual image is 2m away, ie. 1m behind the mirror.
In that case 1/f is indeed 0 and f is infinite (or undefined), because parallel rays striking a plane mirror are still parallel after reflection.
I don't think there is any mirror with focal length 0, but all plane mirrors have 1/f =0
Curved mirrors have different focal lengths, depending on their curvature.
I don't think anything can be gained by trying to guess what you might have meant if you were talking about a curved mirror. If you can explain again the situation you have in mind, giving all distances from the mirror, I'll try to do the right calculation.
