Using Linear Algebra to solve systems of non-linear equations
Edwin
I did some number crunching and found the following:
Given n equations in n unknowns:
a*f(x) + b*g(y) = c
d*f(x) + e*g(y) = f
If there is a solution to these equations, you can use substitution to transform these equations into a set of linear equations and solve using linear algebra.
Let f(x) = u and g(y) = v
Then
a*f(x) + b*g(y) = c
d*f(x) + e*g(y) = f
which becomes
a*u + b*v = c
d*u + e*v = f
Which can be solved for u and v using linear algebra.
x and y can then be solved for by solving the corresponding equations
u = f(x), and v = g(y) thus making it possible to solve systems of non-linear equations of the form above using linear algebra.
Any thoughts?
Edwin G. Schasteen
You aren't using Linear Algebra to solve for x and y.
Linear Algebra can solve for a,b,d, and e if a solution exists. It doesn't do anything regarding x and y.
You can not solve u and v through that at all.
Let f(x) = x^10 + x^9 + x + 1 = u, and g(y) = y^11 + y^10 + y + 1 = v.
According to you, we can solve for u and v.
a*u + b*v = c
d*u + e*v = f
...then for x and y.
Using my simple polynomials, solve for x and y, which you said you can do. To make it easier, let a=1, b=0, and c=0.
a*u + b*v = c
u + 0 = 0
f(x) = 0
x^10 + x^9 + x + 1 = 0
Hmmm... this isn't helping much.
How does Linear Algebra solve that?
a*f(x) + b*g(y) = c
d*f(x) + e*g(y) = f
Then
a*f(x) + b*g(y) = c
d*f(x) + e*g(y) = f
which becomes
a*u + b*v = c
d*u + e*v = f
Any thoughts?
Edwin G. Schasteen
What you are saying is certainly true but I don't see anything new. If I had, for example, the two equations
x2+ y2= 1 and
x2- y2= 1 then I would add the two equations to get 2x2= 2 so x= 1 or -1. Putting that back into either equation I would have 1+ y2= 1 or 1- y2= 1 both of which give y2= 0 or y= 0. The two solutions to the system of equations are x= 1, y= 0 and x= -1, y= 0.
Of course, you are assuming that you have n LINEAR equations in n functions of single variables. Most "non-linear" equations are more complicated than that: for example x2- 2xy+ y2= 1 and x2+ ey= 1 or sin(x)+ cos(x)= 1.
Maybe I misread your question.
Is u and v constants?
Let me try explaining it a different way:
Suppose the system of equations
au + bv = c
du + ev = f
has a unique solution (u,v) = (m,n). (As is typical with 2 equations and 2 unknowns)
Then, if you were asked to solve the system of equations
a*f(x) + b*g(y) = c
d*f(x) + e*g(y) = f
for x and y.
The previous work allows you to immediately reduce this problem to solving
f(x) = m
g(y) = n
au + bv = c
du + ev = f
a*f(x) + b*g(y) = c
d*f(x) + e*g(y) = f
for x and y.
f(x) = m
g(y) = n
Yes, but that doesn't really help at all.
Really? I think solving
x^10 + x^9 + x + 1 = 7
y^11 + y^10 + y + 1 = 3
looks much much easier than trying to solve
5y^11 + 3x^10 + 5y^10 + 3x^9 + 3x + 5y + 8 = 36
y^11 - x^10 + y^10 - x^9 - x + y = -4
Don't you?
And how else were you planning on solving the equation
cos t + 3 sin s = 2
4 cos t - 2 sin s = -1
Thanks for your input guys!
Hurkyl, I hadn't thought of using this to solve systems of transcendental equations. That's an interesting thought!
Your thoughts regarding simplification of the systems of algebraic equations of the same form into more managable equations of a single variable were exactly what I was aiming at. Given a system of non-linear equations of the form below, you can reduce the equations to a system of non-linear equations of a single variable for each of the variables just as you've shown below. One can then use any variety of numerical methods to approximate sollutions to the given equations.
What do you think?
Inquisitively,
Edwin
It's what I would expect to be taught in any intermediate algebra course.
The crucial point is that "non-linear equations of the form below" are not general non-linear equations. Your form is restricted to "linear equations of non-linear functions of a single variable". Obviously one can use linear equation methods to reduce to separate non-linear equations.
That's correct.
Best Regards,
Edwin
