18v drill battery to 5v regulator?
To charge an iPhone from an 18V Dewalt drill battery, a switching DC-DC buck regulator is recommended for efficient voltage conversion to 5V, avoiding the need for heat sinks. A 7805 regulator is less efficient and may require additional components like a 7812 regulator. Pre-built modules for this conversion are available online, and users are encouraged to check specifications to ensure compatibility. When selecting a regulator, it's important to verify whether external capacitors are needed based on the datasheet. Overall, using a suitable buck converter will provide a consistent 5V output for charging.
Coxyboy
18v drill battery to 5v regulator??
Hi I have been doing a bit of research but am still a little unsure,
I am trying to charge an iPhone from a dewalt drill battery,
What I have so far is that the iPhone is a 5v 1000ma supply
And the dewalt battery is 18v lithium ion
Can I use a 7805 regulator or will I have to use a 7812 regulator first?
Also what heat sinks etc would I need
Thanks for any help
Sorry not up on the electronics ! Ha
Thanks for any help
It would be much more efficient (the Dewalt battery will last longer, and you won't need heat sinks) if you use a switching DC-DC buck regulator to convert from 12V to 5V. You may be able to find a pre-built one, or there may be simple electronics kits that you could solder together to do this...
This regulates the voltage - USB Charger
Any choice of these is the power supply, ensure it is rated at 7.4v or 2s (3.7*2) - Batteries
These are the proper plugs for the battery(s), "female" are for the batteries - Plugs/adapters
Chargers can be had on the cheap too, most are offered without a power supply themselves - Cheap wall charger good for 3000mah (about a 5 hour charging time)
probably total $40-50 incl shipment to an open trade area for a 3000mah power supply for usb charging...not bad at all. Oh but requires mere guerrilla precision soldering skills.
Coxyboy said:
Will something like this do?
http://item.mobileweb.ebay.com/viewitem?itemId=251276533029&cmd=VIDESC
How will I get a consistent 5v supply out and it has a vout range above and below?
I don't see a datasheet at that page (I may have missed it), so it's not clear how to set the output voltage. I'd stick with a fixed version, like the one I posted. Because cars use 12V batteries, 12V to 5V step-down converters are pretty common.
Will this be suitable ?
http://uk.rs-online.com/mobile/p/switching-regulators/6664379/
As I am In The uk I have been checking local sites will I need anything else?
Sorry for the questions
Thank you in advance
That looks like a reasonable candidate. Check the datasheet to see if you need to add external capacitors --they may be included inside though.
http://www.tracopower.com/products/tsr1.pdf
According to the data sheet an input capacitor is only needed when input is greater than 32v so hopefully this will be all I need I will order it and let you know how I get on thanks
