Circular Motion and static friction
The discussion revolves around calculating the maximum speed of a car rounding a turn and the dynamics of a bucket being whirled in a vertical circle. For the car, the static friction provides the necessary centripetal force to prevent it from sliding out of the curve, confirming that centripetal force can indeed be equal to static friction. In the case of the bucket, the tension in the rope and gravitational force must be analyzed to determine the speed at the lowest point and the minimum speed at the top to prevent slack. The correct approach for calculating forces involves understanding the direction of tension and gravity, particularly at different points in the circular motion. Ultimately, the discussion emphasizes the relationship between forces acting on objects in circular motion and the conditions required to maintain that motion.
MIA6
1. What is the maximum speed with which a 1050-kg car can round a turn of radius 77 m on a flat road if the coefficient of static friction between tires and road is 0.80? What does the static friction have to do with this problem? Is the centripetal force equal to this friction? WHy?
2. A bucket of mass 2.00kg is whirled in a vertical circle of radius 1.10 m. At the lowest point of its motion the tension in the rope supporting the bucket is 25.0 N. a) Find the speed of the bucket. b) How fast must the bucket move at the top of the circle so that the rope does not go slack? for a), I got Fcp=Ft-Fg, ('t' means tension) but someone said it was Fcp=Ft+Fg. But tension and the gravity acts in opposite direction at the lower point?! for b), someone said Ft=0? why?
Thanks.
Yes it is. What other forces could possibly be the centripetal force besides friction? Think of it this way. The car wants to slide out of the curve and move off tangent to it. Static friction holds the car "in place" in that direction. (i.e. at the same radius from the center)
For part a you are right that Fcp=Ft-Fg. For part b, what will be the the acceleration for which the bucket just makes it around the loop? If you know this, you should be able to find the net force on the bucket, and find the speed of the bucket.
If the bucket has no tension, but only gravity, can it still make a vertical circle? Will it fall down? OH, I think it will not because it still has the net force, or centripetal force.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
