1X or 10X Passive Voltage Probe?
  • Thread starter Thread starter vze3bbyp
    Probe Voltage
In measuring an 800kHz, 30ppV sine signal across a 115pF, 10Ohm RC circuit, the choice between a 1X and 10X passive voltage probe is critical for accuracy. The discussion reveals that the 1X probe provides measurements that maintain a resistance value closer to the known resistor compared to the 10X probe. This suggests that the 1X probe may be more accurate for this specific application. Additionally, the user seeks alternative methods to objectively verify the accuracy of both probes in measuring voltage across the RC circuit. Overall, the 1X probe appears to be the preferred choice for precise voltage measurement in this scenario.
vze3bbyp
Hi All,
Suppose you have applied 800kHz, 30ppV sine signal (from a pulse generator) to a 115pF, 10Ohm RC circuit and you want to know the value of the applied voltage as accurate as possible what passive voltage probe would you use, 1X or 10X? Is there a way to check the accuracy of the two measurements? What I do is I use a resistor of known resistance and I divide the current passing through it into the voltage across it measured alternatively with the 1X and the 10X probe. What I see is that throughout one period of the sine wave the 1X probe sustains an R value closer to the known R value than the 10X probe. This makes me conclude, although I'm measuring the voltage across the R and not the voltage across the RC, that the 1X probe is more accurate. Am I right and are there other ways I can objectively check the accuracy of the two probes with regard to measuring the voltage across the RC?
vze3bbyp said:
Hi All,
Welcome to the PF.
The Tektronix 'scope probe primer should be useful reading for you. It is available at this Tek tutorial page:
http://www.tek.com/learning/oscilloscopes/
You need to register to download it, but the registration is free.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
