2 Questions about EM wave propagation
The discussion centers on two questions regarding electromagnetic (EM) wave propagation. It notes that when the electric (E) and magnetic (B) fields of an EM wave are at zero, it indicates periodic points in space where either field is absent, similar to moments in a water wave. EM waves can travel indefinitely in a vacuum, but in matter, they are attenuated because they interact with charged particles, transferring energy and causing electron movement. This interaction can lead to energy being converted into other forms, such as heat, as the wave propagates through the material. Understanding these properties is crucial for applications involving EM waves in different media.
Cornfused
I was just reading about EM wave propagation and had two questions I would appreciate an answer to.
1-I read how the electric and magnetic fields of an EM wave oscillate sinusoidally and perpendicular to each other and the direction the wave is traveling. Is there any significance or special properties of an EM wave when the E and B fields are at zero or both on the axis in the direction of propagation?
2-As I understand it, EM waves can travel indefinitely in a vacuum, but not in matter. What is it that causes waves in matter to (for lack of a better word) stop or wear out? Is the energy in a wave converted to another form when it hits the atoms of the matter it is traveling through?
If it is easier, you can post a link that explains the answers. Thanks
I'll have a go at 1. It just means E = 0 or B = 0 (never both) periodically at any point in space. It is like noticing that as a water wave passes you there are times when the water level is normal (as if there was no wave).
EM waves are attenuated in matter due to them exerting forces on charged particles, transferring energy to them. The wave makes the electrons move, perhaps even pulling some away from their atoms.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
