Understanding Naming Compounds and Isomers | Common Chemistry Questions
  • Thread starter Thread starter BH20
The discussion revolves around two main questions regarding the naming of hydrocarbons and the distinction between structural and geometric isomers. For naming hydrocarbons, the key steps include identifying the longest carbon chain and noting any branches, as well as specifying the position of double bonds. The example provided, CH3 - C = CH - CH2 - CH3 with a CH3 branch, is named 2-methylprop-2-ene, emphasizing the importance of the carbon count and the location of functional groups. The second question addresses the confusion between structural and geometric isomers. Structural isomers differ in the connectivity of atoms, while geometric isomers have the same connectivity but differ in spatial arrangement. The discussion also touches on naming coordination compounds, with examples provided, although the naming process for these compounds was not fully detailed in the conversation. Overall, the thread highlights the complexities of organic chemistry nomenclature and the nuances of isomer classification.
BH20
thought I'd ask here too..I have 2 quick questions.
One is on naming compounds (hydrocarbons)
a) CH3 - C = CH - CH2 - CH3
CH3
(the CH3 should be under the C)
what's the key? is number one counting up how many C and H's there are? which element is first?
my second question is on structural and geometric isomers. I've read up on both but just when I think I understand I read something else and it confuses me. In one or two lines, what's the difference?
I thought it was simply a geometric isomer would have to be GEOMETRICALLY shaped differently, but apparently that is not true.
Thanks
Chemistry news on Phys.org
CH3
Thanks
nm, I figured this out.
however, I don't see how to do it the other way around:
I have some substances and I need to name them.
a) [Cu(Cl4)-2
b) Ag(NH3)+2
c) Cu(NH3)4SO-4
d) Al(H2O)6Cl3
Thanks a lot.
CH3
I know you say you can do this but I would like to post a hint for others that may read this.
First count the longest chain of carbon atoms. If the compound (above) did not have the extra branch then it would be pentene. As there is, then it must be added to the name. In this case the branch is off the 2nd (or 4th) carbon atom (but 2nd is used as it is a smaller number). It has one carbon atom in its make up so it is a methyl- branch. Also, because it is an alkene then you need to state the carbon atom where the double bond is.
The full name is, therefore, 2-methylprop-2-ene.
The Bob (2004 ©)
I'm sure The Bob meant to say 2-methylpent-2-ene
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
