200kg Astronaut, 2.0 m/s, 100.0 N rocket ?
  • Thread starter Thread starter jacksonjw81
    Astronaut Rocket
To stop a 200 kg astronaut moving at 2.0 m/s relative to a spacecraft, a 100 N rocket backpack must be fired for 4 seconds. The calculations clarify that the initial momentum of 400 kg*m/s can be countered by applying the rocket's force over time. Each second of firing reduces the velocity by 0.5 m/s, leading to a total decrease of 2.0 m/s after 4 seconds. The discussion emphasizes the importance of understanding momentum versus force in solving the problem. The final conclusion confirms that the astronaut can effectively halt their motion with the specified rocket duration.
jacksonjw81
[SOLVED] 200kg Astronaut, 2.0 m/s, 100.0 N rocket ?
A 200.0 kg astronaut and equipment move with a velocity of 2.00 m/s toward an orbiting spacecraft . How long will the astronaut need to fire a 100.0 N rocket backpack to stop the motion relative to the spacecraft ? Give your answer in s.
F=ma
W=mg
m=w/g
a=F/m
I know I am missing something so simple. I have spent too long trying to solve this problem and have given up.
F=(200kg)(2 m/s)=400 kg*m/s=
F=400N/s
I don't know what to do with the 100N for the rocket pack, I'm getting lost in all the different conversions.
Please Help
Why don't you start by applying 100N for one second, and see what the final speed is?
There is definitely a way to apply the equations, but understand it intuitively and it'll make more sense.
Also, in your "F=(200kg)(2 m/s)=400 kg*m/s^2", you have an extra 1/s on the right side.
Look again at the units. That should be 200\,\text{kg} 2\,\text{m}/\text{s} = 400 \,\text{kg-m}/\text{s}. The product of velocity and mass is momentum, not force. An alternative expression for kg-m/s is Newton-seconds. That 400 kg-m/sec is the same as 400 Newton-seconds, and this form should tell you exactly how long the rocket pack needs to be fired.
So if the Astronaut has a Force of 400 Newton-seconds and he fires a 100 N rocket then the answer will be 4 s?
If that is the correct answer I'm going to be pissed that is the solution I came up with when I first began working this problem. But, thought that it was to easy and couldn't be right.
Pretty much. For each 100N force applied for 1 second, the decrease in velocity is 0.5m/s.
In 4 seconds, -2.0 m/s decrease in velocity.
Enjoy.
In 4 seconds, -2.0 m/s decrease in acceleration.
Enjoy.
Thanks
