What is the equation for average angular acceleration?
The equation for average angular acceleration is α = Δω/Δt, where Δω represents the change in angular velocity and Δt is the change in time. The initial confusion arose from mixing it up with the formula for average angular speed, which is W avg = Δθ/Δt. Clarification was provided that the average angular acceleration specifically focuses on the change in angular velocity over time. This distinction is important for accurately understanding rotational motion. The discussion concluded with appreciation for the clarification received.
Fed22
I was just wondering what the equation for average angular acceleration is
At first i thought it was W avg = Delta Pheta/ Delta Time
but then i think that might be the Average Angular Speed formula...
Any ideas? i know it's a simple question so hopefully no one will get annoyed =P
more like
\alpha = \frac{\Delta \omega}{\Delta t}
Thanks that helped! =)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
