Is Momentum Conserved in a Lever System?
Momentum is not necessarily conserved in a lever system, as demonstrated by the discrepancy between input and output momentum when forces are applied. When a force of 1 Newton is applied to a lever, it results in a greater output force of 10 Newtons at a different point, suggesting that momentum is being drawn from the lever itself. The relationship between force, time, and momentum indicates that kinetic energy increases with the square of both force and time, complicating the conservation equation. Additionally, while angular momentum is conserved, the mass of the lever can affect the overall momentum balance, particularly if the lever is nearly massless. Ultimately, the conservation of momentum in this context raises questions about the source of the additional momentum observed.
kmarinas86
We will apply a force of some distance for some period of time.
Let's say the goal is to apply a maximum force over a small distance.
We apply 1 Newton at right angles to a frictionless lever, 1 meter from the pivot point.
At 10 centimeters from that pivot point is an object that weighs 1 kg, and the force it receives is 10 Newtons. Because the force is 10 Newtons, the object gains 10 kg*m/s of momentum per second. Two special situations may be considered:
1) Had the force been higher, the object would gain greater than 10 kg*m/s due to greater acceleration.
2) For the same force, a heavier mass would accelerate more slowly but it would still absorb momentum at the same rate as determined by that same force.
The force on each lever arm is inversely proportional to the radius of each lever arm. Therefore, it can be assumed that this system as currently revealed involves the conservation of angular momentum. It also conserves energy. If one increases the length of the arm of input, the effort needed to be applied to do the same amount of work directly decreases.
The question then is, will the momentum going into the lever equal the momentum going out of the lever? If the force going into the lever is 1 Newton, it is absorbing momentum at a rate of 1 kg*m/s per second. If the force going out of the lever is 10 Newtons, it is applying momentum at a rate of 10 kg*m/s per second. This defies common sense. It implies that a rate of momentum utilization of 9 kg*m/s per second is unaccounted for. The question however is, what is the direction of that force? That force is anti-parallel to the force applied on that lever. If we ignore the lever itself and simply accounted for the input and output forces (which are in opposite directions), common sense tells us that a rate of momentum of 9 kg*m/s is being utilized from whatever medium to which the force of 1 Newton is applied and from which the force of 10 Newtons comes from. The momentum, it seems, would have to come from the lever itself. Incongruous!
Even more shocking is when we consider the Newtons applied over a period of time. A force times time equals a change in momentum. Apparently, the kinetic energy stored in some mass would increase with the square of the force and the square of the time the force is applied, assuming a constant force and mass. For a given untethered mass, we could apply twice the force for half the time or half the force for twice the time and it would result in the same kinetic energy gained. The question is however, how far does the lever arm move in that time period. In the case of a lever arm of twice the length, half the force is applied resulting in the same acceleration of the object with the same torque, and the force is made at twice the velocity, resulting in the same power input (since force*velocity=power; e.g. prony brake). The opposite case occurs for a lever arm half as long with an applied force twice as much. Again, moving the same mass at the same rate does not affect the input power or input torque.
However, starting with the same lever arm, the input force * the input arm radius / the output arm radius = the output force. We return to the conundrum we found where output momentum exceeded input momentum, suggesting that the momentum came from the lever itself. If we think the input lever arm radius * input force as the calculation for torque, and if we recognize that torque is quantified as angular momentum transferred per unit time, we can easily see that angular momentum is conserved.
KE = 1/2 * mv^2
where
KE = Kinetic Energy
m=mass
v=velocity
p = mv
where
p = momentum
m=mass
v=velocity
KE = 1/2 * p^2/m
where
p^2/m = mv^2
F = p/t
where
t=time
p=F*t
KE = 1/2 * (F*t)^2/m
where
KE = F*d
d=1/2 * (F/m)*t^2
(F/m)=acceleration
d=1/2 * a * t^2
v_initial=0
d=change in position
These formulas are consistent with physical knowledge and with the above paragraphs.
Lesson: Conservation of momentum is really the conservation of ANGULAR momentum.
Not necessarily. The lever could be (nearly) massless. In that case it would have no momentum or kinetic energy at all.
After a quick scan, the things you said are correct. But it is so much harder to understand and error prone in verbal form rather than equation form.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
