Why do my speakers pick up radio stations?
  • Thread starter Thread starter mr-tom
    Radio
Logitech speakers can pick up radio stations due to poor internal wiring that acts as an antenna, allowing them to demodulate and amplify radio signals. This phenomenon often occurs when speakers are not properly shielded, especially in areas with strong radio transmissions. Users may notice this issue more prominently when speakers are connected to a computer or other devices. Instances of similar problems have been reported in buildings near powerful radio antennas, where entire floors experience interference. Overall, this is a common issue linked to speaker design and environmental factors.
mr-tom
I get random radio broadcasts coming from my logitech speakers when they are turned on but with no volume. Why is this?
Because they're poorly made. Some of the wiring inside the speaker acts as an antenna, and some part of the circuit provides the diode behavior necessary for demodulation. The resulting audio frequency energy is faithfully amplified by the power amplifier, and viola, you have a radio.
- Warren
Is this at home? Are they plugged into a computer? Do you get the radio when you unplug them from the computer?
My company helped a building in Philly with a problem where the frame of the building was receiving radio waves and everything with a microphone or speakers on certain floors would play the radio station being broadcast from next door.
We had to build what amounts to a Faraday cage around a computer next to WNBC in Washington DC ... long loooong ago.
What you see is not all that uncommon, especially if there is a powerful radio antenna nearby.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
