Gauss's Law- Flux through surface
The discussion revolves around calculating the electric flux through a flat surface in a uniform electric field using Gauss's Law. The user initially miscalculates the area vector and the dot product, leading to incorrect flux values. Guidance is provided on the proper definition and calculation of the area vector, emphasizing that only one component should be nonzero for a flat surface in the x-y plane. The user acknowledges the mistake and seeks further clarification on the correct approach. Ultimately, the focus remains on accurately defining the area vector to solve the flux calculation correctly.
chipperh
A flat surface with area .14 m^2 lies in the x-y plane, in a uniform electric field given by E=5.1i +2.1j+3.5k kN/C.
A) Find the flux through the surface.
Flux = E dot A (Vector math?)
I believe this is the dot product of two vectors. Converting the surface area to vectors (i,j,k) I come up with (.374i, .374j, 0k). When I calculate the dot product:
(5100, 2100, 3500) (.374, .374, 0) I get 2694 N M^2/C (wrong). I believe the plane vectors are incorrect. Guidance please?
Thanks again.
Chip
What is the definition of an area vector, \vec{A}? This is where you are having trouble.
Thank you for the push in the direction. I understand I have to convert the area into a vector. I have been looking through my old notes and texts on this subject. Since the area is assumed to be flat (no 'z' (k) component), I assumed zero for that value. I took the square root of .14 m^2 (oops) ... I think this is where I made my mistake.
Will forge ahead!
Ok, with this problem, I am obtaining the dot product of the two vectors. I believe the vector for the 'plane' would be N= [.14 + .14 + 1]
When I do the dot product as follows:
Ex*Nx + Ey*Ny + Ez*Nz = # NM^2/C
5100*.14 + 2100*.14+3500*1 = 4508 N M^2/C for the flux through the surface. This is wrong though. Another nudge please?
Thank you.
Chip
According to your most recent response, your definition of the area vector is still not correct. See the link: http://en.wikipedia.org/wiki/Vector_area
According to this problem, there is only one nonzero component of the area vector.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
