2nd Order Differential Equation (Complex)
roam
Find the general solution to the following differential equation:
\frac{d^2 y}{dt^2} - 2 \frac{dy}{dt} + 2y =e^t
The correct answer must be: y(t) = C_1 e^t \cos t + C_2 e^2 \sin t +e^t
I haven't been able to get the correct answer so far. The eigenvalues are:
\lambda^2-2 \lambda +2 = 0
\lambda = \frac{2 \pm \sqrt{4-8}}{2} = 1 \pm i
So the general solution of the corresponding homogeneous equation is:
y_h(t) = C_1 e^{(1-i)t} + C_2 e^{(1-i)t}
And with inspection a particular solution is yp = et, so the general solution must be:
y(t) = C_1 e^{(1-i)t} + C_2 e^{(1-i)t} + e^t
Using Euler's formula:
y(t) = C_1 \frac{e^t}{\cos t + i \sin t} + C_2 e^t (\cos t + i \sin t)+ e^t
So, why is my answer so different from the correct answer provided? What do I have to do in order to get the correct answer?
Any help is really appreciated.
The general solution of the reduced equation should be:
y_c=e^{t}(C_1 \cos t + C_2 \sin t)Then, use the method of variation of parameters to find the particular integral.
I think you mistyped the answer as i got the general equation: y(t) = C_1 e^t \cos t + C_2 e^t \sin t +e^t
The homogeneous solution should be written$$y_h(t) = C_1 e^{(1+i)t} + C_2 e^{(1-i)t} + e^t
=C_1e^te^{it}+C_2e^te^{-it} =
C_1e^t(\cos t + i \sin t)+C_2e^t(\cos t - i\sin t)$$from which you can get the sine - cosine form by collecting terms and renaming the constants.
Yest, that was a typo I meant et not e2.
Thanks a lot LCKurtz for the hint, I finally got the correct expression.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
