How Do You Calculate Acceleration and Time in Kinematics?
To calculate acceleration in kinematics, the formula a = (v_f - v_i) / (t_f - t_i) can be applied, where v_f is the final velocity and v_i is the initial velocity. Given the velocities of 55.8 m/s at x = 5.5 m and 100.4 m/s at x = 10.5 m, the acceleration can be determined using these values. The time taken for the particle to accelerate from 55.8 m/s to 100.4 m/s can be calculated once acceleration is known. Additionally, to find the velocity at x = 27.3 m, the kinematic equations can be utilized. Understanding these calculations is essential for solving kinematic problems effectively.
sabresfan2000
An object moving with constant acceleration has ve-
locity v = 55.8 m/s when it is at x = 5.5 m and v = 100.4 m/s
when it is at x = 10.5 m. What is its acceleration?
How much time does it take for the particle to accel-
erate from 55.8 m/s to 100.4 m/s?
How fast will the particle be moving when it is located
at x = 27.3 m ?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
