3 pulleys - 2 masses on incline plane
The discussion revolves around analyzing a system of three pulleys with two masses on an inclined plane to determine if the log will move up the ramp. Key calculations involve the forces acting on both blocks, with specific attention to the tension in the ropes and the effects of friction and incline angle. It is established that if one block descends, the log moves up the slope, but the distance moved by the log is half that of the descending block due to the pulley configuration. The relationship between the distances moved leads to the conclusion that the acceleration of the log is half that of the block. Ultimately, the analysis confirms that the log will indeed move up the ramp under the given conditions.
Saints-94
http://tinypic.com/r/qs9q4o/9 http://tinypic.com/r/qs9q4o/9
Verify that the log will move up the ramp under the given conditions
m1 = 220
m2 = 130
mu = 0.4
theta = 25
g = 9.81
N = (m1*g)*cos(theta)1) m2g – T = m2a Forces acting on Block B
2) 2T – m1g*sin(theta) – mu*N = m1a Forces acting on log1) T = m2g – m2a
2) 2 (m2g – m2a) – (m1g*sin(theta)) – mu*N = m1a2m2g – 2m2a – (m1g*sin25) – (0.4 * N ) = m1a
(220*130*9.81) – (220*9.81*sin25) – (0.4*1956) = m1a + 2m2a
(2550.6) – (912.1) – (782.4) = a(m1+2m2)
856.1 / (m1+2m2) = a
856.1 / (220+260) = aa = 1.78m/s^2
Unsure about the forces acting on the double pulley. I am right to assume it is 2T? Does this give me the correct value of 'a' to assume the log is accelerating up the slope? [/B]
Yes. Is that incorrect?
At the same time as you replied, I deleted my post because I noticed you later had 2a terms, so I thought I should check whether you had defined a as the acceleration of one and were using 2a for the acceleration of the other. But having checked, no, it seems you did use a for both.
The rope is constant length. As the weight descends a distance y, what happens to the three sections of rope?
The rope carrying Block B increases as the block lowers. The two lengths of rope carrying the log stay equal to each other and shorten. Is that what you were asking?
Yes, but a bit more detail... if block B descends a distance y, how much do the two lengths holding the log shorten by?
What does that tell you about accelerations?
If block B decends by 1m, then the log will move 2m due to the two pulleys?
No. One step at a time, no wild guesses please.
You wrote, correctly, that the two ropes parallel to the slope remain the same length as each other. We also know the total length of the rope is constant. Write that as an equation relating the lengths of the sections.
Is the rope pulling the log two times the length of the rope supporting the block?
I got nearly the same the answer (rounding error) so that could be a good sign. I treated the force on the double pulley as 2x like you, I am pretty sure that's the way to do it, I could be wrong though. A little tip, I like to break down each force into each direction, form a sum of forces in each direction then form a triangle of the resultant force (being the hypotenuse), just the way my teacher taught me. It makes it nice and simple for figuring out which force is going where.
I said no wild guesses.
Let the total length of the rope be L.
If the vertical length is y, how long are the other two sections?
I believe the other two sections would both be y also?
If we are saying that force from the block is doubled due to the set up of the double pulley then something has to compensate... the distance moved.
That would make the total length 3y, but, since the total length is constant, y would be constant, so the weight cannot move?
Please, please, please try writing equations to represent the clear facts:
The total length of the string is constant;
The two lengths parallel to the slope are equal in length.
I will not respond further until you show an attempt to do that.
Yes i agree. Would this affect the acceleration? Would it make the acceleration 2*a at the log?
Previously you stated the total length of the rope was L and vertical was y. In my equations i have labelled the forces acting on the ropes as 2T at the log and T acting against the block. I don't understand what you're asking?
It is not (directly) related to the forces. It is just a matter of the way the lengths of the sections relate to each other.
If each of the sections parallel to the slope is length x, and the vertical section is length y, what equation relates x, y and the total length L?
Is it as simple as 2x+y=L?
Think about the equation of acceleration, distance/time squared, if the log is moving less distance in the same time then...
It is accelerating slower?
Yes!
Now, what does that tell you about the accelerations? What do you do to a distance variable to turn it into an acceleration variable?
haruspex said:
Yes!
I'm not sure, I haven't come across this before.
Have you been taught any differential calculus? Like, velocity = rate of change of position?
V^2 = U^2 + 2as?
Saints-94 said:
V^2 = U^2 + 2as?
No.
Does v =dx/dt ring any bells?
haruspex said:
No.
Yes. But I'm unsure how to apply it to find acceleration.
Then let's try to reason it out without calculus.
You found that 2x+y=L. So if the weight descends 1m, how far does the log move, and in which direction?
It will move up the slope. I'm unsure what distance, but would it be 2m?
Try it in the equation. We've increased y by 1. You are suggesting x will decrease by 2, yes? Does that still give a total of L?
(y+1) + (2x-2) = L ?
No, you suggested the log would ascend 2m, which means each x would lose 2m. That would mean you start with L=y+2x, And end with a string length (y+1)+2(x-2)=y+2x-3=L-3. The string has mysteriously shrunk by 3m.
Try another way of changing x when y increases by 1m.
  • #31
(y+1) + 2 (x-0.5) = y + 2x = L ?
  • #32
Right. The log moves up half the distance that the weight moves down.
Based on that, if the weight descends at speed v, how fast will the log slide up the slope?
  • #33
0.5v?
  • #34
Saints-94 said:
0.5v?
Ok! Now for the one we've been working towards ... how will the accelerations compare?
  • #35
Will the acceleration be twice as much at the block compared to the log?
  • #36
Yes.
But now I should confess something. The question posed is whether the log will move. To answer that, you do not need to worry about how fast it will move. You can suppose that it does not move, so there are no accelerations, and see whether the balance of forces is consistent with that.
However, most multiple pulley questions do involve different accelerations, and I felt it was important you found out how to deal with these.
