How Do You Solve a Double Integral for Area Between z=e^{x^2} and the xy-Plane?
To find the area between the xy-plane and the surface z=e^{x^2}, bounded by x=0, x=1, and y=2x, a double integral is set up as ∫ from 0 to 1 ∫ from 0 to 2x e^{x^2} dy dx. The inner integral evaluates to 2xe^{x^2}, which is then integrated with respect to x from 0 to 1. This results in the outer integral simplifying to e-1. Thus, the area between the xy-plane and the curve is e-1.
tandoorichicken
I was just faced with this problem on a test and I have no idea how to do it Find the area between the xy-plane and z= e^{x^2} as bounded by x=0, x=1, and y=2x.
I have no idea how to do this problem. I set up the integral as
\int_{0}^{1} \int_{0}^{2x} e^{x^2} \,dy \,dx
What is the problem here?
Do the y-integration, and then the x-integration.
First, it's important to note that the xy-plane is the plane where z=0. So, we are essentially finding the area between the x-y plane and the curve z=e^{x^2}.
To solve this problem, we can use the concept of double integrals, where we integrate over two variables (in this case, x and y) to find the area between the two curves.
To set up the integral, we start by integrating with respect to y first, since that is the inner integral. The limits of integration for y are from 0 to 2x, as given in the problem.
Next, we integrate with respect to x, with limits of integration from 0 to 1.
So, our integral becomes:
To solve this, we can use the fundamental theorem of calculus, which states that the integral of a function over a specific interval is equal to the difference of the antiderivatives evaluated at the endpoints of the interval.
In this case, the antiderivative of e^{x^2} is \frac{1}{2}e^{x^2}, so our integral becomes:
\int_{0}^{1} \frac{1}{2}e^{x^2} \,dx
Evaluating this at the endpoints, we get:
\frac{1}{2}e^{1^2} - \frac{1}{2}e^{0^2}
= \frac{1}{2}e - \frac{1}{2}
= \frac{1}{2}(e-1)
So, the area between the xy-plane and z=e^{x^2} bounded by x=0, x=1, and y=2x is \frac{1}{2}(e-1).
It's important to note that this is just one approach to solving this problem. There may be other methods or techniques that can also be used. It's always a good idea to practice different approaches and see which one works best for you.
First, it's important to understand what the problem is asking for. In this case, we are finding the area between the xy-plane (z=0) and the function z=e^{x^2}, bounded by the lines x=0, x=1, and y=2x. This means we are looking for the region in the xy-plane where z=0 and z=e^{x^2} intersect, and the boundaries of this region are given by the lines x=0, x=1, and y=2x.
To solve this double integral, we can follow these steps:
1. Draw the region in the xy-plane: Before setting up the integral, it's helpful to visualize the region we are looking for. In this case, it is a triangular region bounded by the lines x=0, x=1, and y=2x. Draw this region on a graph to get a better understanding of the problem.
2. Set up the integral: As you have correctly done, the double integral is set up as \int_{0}^{1} \int_{0}^{2x} e^{x^2} \,dy \,dx. This represents the area under the surface z=e^{x^2} within the given boundaries.
3. Evaluate the inner integral: The inner integral, \int_{0}^{2x} e^{x^2} \,dy, represents the area under the curve e^{x^2} within the boundaries of y=0 and y=2x. This can be solved by simply integrating e^{x^2} with respect to y, giving us e^{x^2}y evaluated from y=0 to y=2x. This simplifies to 2xe^{x^2}.
4. Evaluate the outer integral: The outer integral, \int_{0}^{1} 2xe^{x^2} \,dx, represents the total area of the region bounded by x=0, x=1, and y=2x. This can be solved by integrating 2xe^{x^2} with respect to x, giving us e^{x^2} evaluated from x=0 to x=1. This simplifies to e-1.
5. Final answer: The final answer is e-1, which represents the area between the xy-plane and z=e^{x^2} as bounded by
