What Is the Maximum Likely Speed of a Gas Molecule in a Typical Room?
  • Thread starter Thread starter CatWoman
    Distribution
CatWoman
The area under the Maxwell-Boltzmann distribution of speeds of molecules of mass m in a gas at temperature T above a speed v can be estimated as
1/2 (m/2πkT)^(1/2) v exp(-(mv^2)/kT)
Show that the maximum likely speed of a gas molecule in the air in a typical room (i.e. the speed above which the Maxwell-Boltzmann distribution gives a probability of 1/N, where N is the number of molecules in the room) is of order 4<v^2>^1/2 (where <v^2>^1/2 = (3kT/m)^1/2).
I think the question means that the Maxwell-Boltzmann distribution curve is approx a 1/N curve at and above a certain value of N. I was going to equate the max-bolt curve equation to 1/N, except the question gives the equation for the area. Then I thought I should integrate the 1/N curve to get the area then 1/N dN gives ln N. Then I can equate the areas. Then use PV=NkT so that
ln(PV/kT) = 1/2 (m/2 pi kT) exp -(mv/kT)
I was then going to plug in values for T (293Kelvin) and m (mass of nitrogen molecule) but this is really hard to solve for v so I think it must be wrong.
Any help would be really great! Thanks
If you recall from calc, when you want to find a max or min, you need to take a derivative...
Oh yeah! So if iI have the formula for the area then I need to differentiate twice then set equal to zero to get the maxima? I did this and got V^2=(18 pi k T/m)^1/2. This doesn't match the answer so I don't know if my working is wrong or something else.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
