What is the difference between synchronous and asynchronous motor?
A synchronous motor operates at a speed that is directly tied to the frequency of the AC voltage supply, maintaining a constant speed based on the number of magnetic poles. In contrast, an asynchronous motor typically runs slower and its speed can vary with the mechanical load it drives, relying on the slip between the rotor and the synchronous frequency to generate torque. Induction motors are a common type of asynchronous motor, where torque is produced through the interaction of the stator's magnetic field and induced currents in the rotor. Most DC motors are considered asynchronous due to the absence of a periodic time signal, although some types, like stepping motors, can be synchronous. Understanding these differences is crucial for selecting the appropriate motor type for specific applications.
samieee
hi all
i want to know What is the difference between synchronous and asynchronous motor?
thanks
A synchronous motor runs at a speed which is synchronised to the frequency of the AC voltage that supplies it. For example if the motor is supplied at a frequency of 60Hz then it will run at either 60, 30, 20 etc revs/second, depending on the number of magnetic poles (2, 4, 6 respectively) that it has (by design).
An asynchronous motor generally runs slower than the above with a speed that usually varies somewhat with the amount of mechanincal load that it is driving.
Induction motors are asynchronous because the motor torque is due to the stator magnetic field interacting with currents induced in the squirrel cage (of copper bus bars) in the rotor. In order to induce currents in the squirrel cage, the rotor has to slip with respect to the synchronous frequency. If you have never seen a squirrel cage, take a 1/4 HP induction motor apart and pull the rotor out.
Bob S
may dc motor can be asynchronous??
Most dc motors, including both brush motors (series connected, shunt connected, permanent magnet) and brushless motors are asynchronous, in part because there is no periodic time signal. There are many types of stepping motors that are inherently synchronous to a clock. Also, Hall-Effect sensor-type brushless motors can be synchronized to an external clock. Other dc motors can be controlled by feeding back an RPM signal to a controller.
Bob S
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
