Solving Isothermal Expansion Problem - Temperature Calculation
The discussion revolves around calculating the temperature during an isothermal expansion of a monatomic ideal gas. The initial pressure is given as 400 kPa, with an initial volume of 20 m³ and a final volume of 80 m³. The user initially calculated the temperature using the ideal gas law but received an incorrect result from the grading system. Upon further analysis, it was determined that the large temperature value of approximately 5979 K is indeed correct, given the significant volume and mole count of the gas. The calculations highlight the relationship between pressure, volume, and temperature in ideal gas behavior, emphasizing the need for accurate conversions and understanding of the gas laws.
morsel
Suppose 161 moles of a monatomic ideal gas undergoes an isothermal expansion as shown in the figure (attached). The horizontal axis is marked in increments on 20 m3
What is the temperature at the beginning and at the end of this process?
PV = nRT
Pi = 400 kPa
Vi = 20 m3
Pf = 100 kPa
Vf = 80 m3
T = (PV)/(nR) = (400*20)/(161*8.31) = 5.98 K
My answer is wrong according to the online homework grading system. What am I doing wrong?
Any help is appreciated.
The pressure is kilo pascal.
OK. But even if I convert kPa to Pa and calculate, that's still not the answer.
T = (400,000 Pa * 20) / (161*8.31) = 5979 K
This seems outrageously large.
True. But you can blame the person who drafted the question. That is the right answer to this question.
One mole of a gas at STP occupies 22.4 litres or .0224 m^3. That is at about 100 kPa pressure and a temperature of 273 K. Here, you have 161 times that amount of gas occupying 80/.0224 = 3571 times as much volume. So to reach the same 1 atm pressure the temperature has to be 3571/161 = 22 times the temperature at STP -about 6000 degrees.
AM
Okay. Thanks for your help.
