Show that the units for all 3 terms in bernouliis equation are the same
  • Thread starter Thread starter victoriafello
    Terms Units
The discussion focuses on verifying that all terms in Bernoulli's equation have the same units. The participants analyze the units for pressure, density, velocity, gravitational acceleration, and height, ultimately expressing each in terms of basic units: kilograms (kg), meters (m), and seconds (s). They confirm that the units for pressure (kg m^-1 s^-2), kinetic energy per unit volume (½ρv²), and potential energy per unit volume (Pgh) all simplify to the same dimensions. The conclusion emphasizes that since all terms share the same units, the constant on the right side of the equation must also match these units. The discussion effectively clarifies the dimensional consistency of Bernoulli's equation.
victoriafello
bernouliis equaton
P + 1/2 Rho v^2 + Rho g h = constant
find the units of the three terms on the left hand side & show they are the same and then the units of the constant on the right
all i can think to do here is check the SI units for each term
units for pressure = Pa or NM^-2
units for density = kg/m^3
units for velocity =m/s
units for g = m/s
units for h = m
but i can't see how i combine them or how they all come out the same ?
Pressure P = NM^-2 = kg*M*s^-2*M^-2 = kg*M^-1*s^-2.
Similarly work out for the other two expression. You can see that all the tree terms have the same dimensions.
Express each factor in terms of the basic units: m, kg, s. Then work out the units of each term in the equation by multiplying the units of each factor.
Hint: Express the pressure in terms of those three basic units.
units for g = m/s
Those units should be ms^-2.
Ok so pressure becomes kgm^-1 s^-2, then the other terms expressed in
M , kg, s are
½ pv^2 is Kg m^-3 m/s^-1
Pgh is kg m^-3 m/2^2
I think I am still having a problem with the powers thou, I am not combining the units correctly
Good.
M , kg, s are
Show how you got these.
What are the units for density? For v?
density is mass / volume so its units are Kg m^-3
for velocity units are m/s^-1
so combined you get Kg m^-3 m/s^-1
and for the second part
density - Kg m^-3
units for g = m/s^-2
units for h - m
combines to give Kg m^-3 m/s^-2
i must be getting this wrong but i have re read my textbook and i can't see where to correct it,
The dimensions of velocity are [L]^1\times [T]^{-1}
The dimensions of velocity squared are [L]^2 \times [T]^{-2}
The density units are correct, but velocity has units of m/s or m*s^-1.
Not quite. The units for ½ρv² would be:
[kg*m^-3]*[m*s^-1]² = [kg*m^-3]*[m*s^-1]*[m*s^-1]
See if you can simplify that by collecting all the powers of m and s. (For example, what's m^-3*m*m simplify to?)
Ok I think I see it now,
So m^-3*m*m simplifies to m^-1
And s^-1*s^-1 simplifies to s^-2
So the units for ½ρv² would be kg m^-1s^-2
Then for the second term
Units for density are kg*m^-3
Units for g are m*s^-2
Units for h are m
This is
[kg*m^-3]*[m*s^-2]*[m]
Collecting the m terms gives m^-1 so the units are
Kg m^-1s^-2
Then all I need is the units for the constant at the end, if the three terms all have the same units then the constant must be in the same units to the power 3, like if you have a volume then m*m*m the result is m^3 ?
if so how do I do this for kg m^-1s^-2 ?
Units for h are m
This is
Kg m^-1s^-2
Good.
Don't confuse three terms (which add) with three factors (which multiply). All the terms have the same units, including the constant. So you're done.
thanks so much for your help !
