Electric Fields Question- Uniform Field
r34racer01
Throughout space there is a uniform electric field in the -y direction of strength E = 540 N/C. There is no gravity. At t = 0, a particle with mass m = 3 g and charge q = -17 µC is at the origin moving with a velocity v0 = 25 m/s at an angle θ = 25° above the x-axis.
(a) What is the magnitude of the force acting on this particle?
F = 0.00918N
(b) At t = 6.5 s, what are the x- and y-coordinates of the position of the particle?
x = ? y = ?
HELP: Recall and apply the kinematic expressions for 2-D projectile motion from mechanics.
E = F/Q = (KQ)/r^2
Range = (vo^2*sin(2Θ))/g
Trajectory = x*tan(Θ)-(1/2)((g*x^2)/(vo^2*cos^2(Θ))
v = vo+at
x = xo + v0t+(1/2)at^2
v^2-vo^2 = 2a(x-xo)
Ok pt a.) was really easy but I'm completely stuck on part b. It says to use kinematics equations but I don't see how that can work. We're not given acceleration and we're told gravity is not acting on the particle, and we don't know the speed at t=6.5s. I thought maybe I could set the force from pt a equal to m*a and that gave me 3.06 but the coordinates I got were not correct. Am I suppose to assume that the acceleration is zero since the electric force field is constant?
Hi
acceleration is Force divided by mass
Best regards
F = 0.00918N
x = ? y = ?
E = F/Q = (KQ)/r^2
v = vo+at
v^2-vo^2 = 2a(x-xo)
You calculated a Force. YOu have the mass of the particle, so F = ma... Just got to get the direction of the net force, thus the acceleration correct. Then use your kinematics. But don't use g, use the a you found from F=ma..
whoops, answered above.
Ok well like I said before I tried F = ma => 0.00918 = 0.003kg * a => a = 3.06 m/s^2. I then did x = x0+v0*t + 0.5*a*t^2 ==> x = 0 + 25(6.5) + 0.5(3.06)(6.5)^2 = 227.1425. I then resolved this into x and y components and got x = 205.86 and y = 95.9. These didn't work so I'm still lost.
v0 is a vector doing 25º
E (and therefore F) is a vector going in the y direction.
You must find the velocity in the x and y component, the force in the x and y component (in this case the x component of the force is 0), and apply kinematic's equation on each component.
Hope this helps
The only difference form the classical projectile problem is that the gravitational field is replaced by the electrostatic field, they obey the same laws, only the expression of the force is different(G = mg for gravity, F = qE in this case, F plays the role of G).
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
