Solving Fractions When Numerator Has Higher Degree
  • Thread starter Thread starter Oblakastouf
    Degree Fractions
Oblakastouf
Alright... What are the rules for when the numerator (Top part) of the fraction has a higher degree than the lower part of the fraction.
Something + {*}
... As in what is that SOMETHING based on the numbers?
I have a midterm in like... 50 minutes and this is the only thing I need to know.
Then you divide the two and you have an integer plus the remainder, where the numerator will have a smaller degree than the denominator. The process of dividing may take a little time but it is easy to check if you have the right answer (by simply multiplying your answer with one of the terms). Do you have a specific example?
Since you are talking about a fraction in which the numerator and denominator are polynomials, dividing will give you a polynomial (which corresponds to an integer in "regular" arithmetic) and remainder. The original fraction is equal to that polynomial plus a fraction with the remainder in the numerator, the original denominator as denominator.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
