Calculating Particle's Position at t=13.7s
  • Thread starter Thread starter mohemoto
    Position
To calculate the particle's position at t=13.7 s, the average acceleration is determined to be 1.36 m/s². The velocity graph indicates a linear relationship, allowing the use of similar triangles to find the velocity at t=13.7 s. The area under the velocity curve from t=0 to t=13.7 s represents the displacement during that interval. By calculating this area and adding the initial position of 6.00 m, the final position can be determined. Understanding the relationship between displacement and position is crucial for solving this problem.
mohemoto
The velocity graph of a particle moving along the x-axis is shown. The particle has zero velocity at t=0.00 s and reaches a maximum velocity, vmax, after a total elapsed time, total. If the initial position of the particle is x0=6.00 m, the maximum velocity of the particle is vmax=27.9 m/s, and the total elapsed time is total=20.5 s, what is the particle's position at t=13.7 s?
Given:
t1=0s
t2=20.5s
d1=6.00m
v1=0m/s
v2=27.9m/s
s = at2/2 + v0t + s0
a(avg)=delta v/t
v(avg)=delta d/t
I was able to calculate the average acceleration to be 1.36s (a=27.9/20.5), and I know what the formula for average velocity is. However, what I do not know is how to calculate the average velocity in the time interval of [0, 13.7]. I take it that I cannot just divide the maximum velocity by 2, because that is over the entire time interval and it would not make sense. Could anybody offer any help? And just to be sure, once I find average velocity, it's just a matter of substituting everything into the formula for position, correct?
Thank you.
You don't show the graph that goes with this question. However, be aware that the displacement (not the position) of an object is the area under the v vs.t curve. So if you can figure out the area under the curve from t = 0 to t = 13.7 s, then that is the displacement in that time interval. To find the position, just add x0.
Oh I apologize; the graph is simply a straight diagonal line showing constant velocity, but the problem is, there are no numbers on the axes, so I need to find another way to find average velocity.
You know that v=0 at t=0, that v=27.9 m/s at t=20.5 s and that the two points on the graph are connected with a straight line. This gives you a right triangle of base 20.5 s and height 27.9 m/s. Can you find the velocity at t=13.7 s? Hint: Think similar triangles. Once you have that velocity then you need to find the area of the smaller triangle that has base 13.7 s.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
