Is there a certain material that absorbs X-Rays so that the X-Rays don't escape
Certain materials with high atomic numbers and density can effectively absorb X-rays, preventing them from escaping. The photoelectric effect can be utilized to convert X-rays into electrical current by knocking electrons from one electrode to another, creating a voltage. The efficiency of this process depends on the energy of the X-rays and the method of their production, such as through radioactive decay. Additionally, the penetrating nature of X-rays means they may interact with electrons throughout the material, complicating energy extraction. Understanding these factors is crucial for developing effective X-ray absorption and conversion technologies.
DAnthony.Fisc
Is there a certain material that absorbs X-Rays so that the X-Rays don't escape. Or rather, is there a material that stops the X-Rays from continuing. If there is such a material, is there a way to change the X-Ray into an electrical current?
Yes - the higher the atomic number, Z, which is also the number of electrons surrounding the nucleus, the more electrons there are to scatter X-rays. Atomic density is another factor - more atoms/electrons per unit volume.
The proposed mechanism implies the photoelectric effect. The X-rays would knock electrons off one electrode to the other. The charge separation would produce a voltage. As long as the electrons pass through the load, rather than jump back across the gap, then one could have power supply.
However, one must consider how the X-rays are to be produced, and how much energy is required. Radioactive decay might work.
Then one has to consider that X-rays are penetrating, so they may knock around electrons within the volume of the electron, rather than from the surface.
Hello, I'm currently trying to compare theoretical results with an MCNP simulation. I'm using two discrete sets of data, intensity (probability) and linear attenuation coefficient, both functions of energy, to produce an attenuated energy spectrum after x-rays have passed through a thin layer of lead. I've been running through the calculations and I'm getting a higher average attenuated energy (~74 keV) than initial average energy (~33 keV). My guess is I'm doing something wrong somewhere...
