Interference (Young's experiment) and an adhesive tape
The discussion centers on how adding a 1mm thick adhesive tape with an index of refraction of 1.5 to one slit in Young's experiment alters the interference pattern. The tape increases the optical path length for light passing through that slit, affecting the phase difference between the two beams. This results in a shift in the interference pattern, as the optical path length difference is crucial for determining the positions of the maxima and minima. Participants seek clarification on the implications of this addition and its impact on the overall interference pattern. Understanding the relationship between the index of refraction and optical path length is key to solving the problem.
zimo
At a young's experiment arrangement, there is a 500nm light beam, a distance of 1m from the slits to the screen and a 0.25mm between the two slits
In what way the interference pattern will change if an adhesive tape is being taped to one of the slits with a 1mm thickness and an index of 1.5 (diffraction can be left out of the calculation)
Xmax = nD[Lambda]/d
The problem is presented in a general way, I can't find out what is the point of the adhesive tape addition to the problem.
Can anyone please give a clarification and a possible direction?
Interference depends on the optical path length difference between two paths. Optical path length depends on the index of refraction of the material that the light is passing through, so adding tape increases this path length for one path but not the other. This changes the interference pattern.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
