Need help with structure of stair climbing robot
  • Thread starter Thread starter Umair Mazhar
    Robot Structure
The discussion focuses on designing a stair-climbing robot, highlighting challenges with the mechanical structure compared to electrical and programming aspects. Key insights suggest that two motors are positioned centrally to facilitate sliding motion, possibly using a belt or chain system. The motion could also be achieved through a rack and pinion design, offering an alternative to the belt mechanism. There is uncertainty regarding motor attachment to the wheels, which remains a point of confusion. Overall, the conversation emphasizes the need for clarity on the mechanical components to achieve effective movement.
Umair Mazhar
Im supposed 2 design a robo like this 1, but here, the mechanical part seems more tought thn the electrical and programming. I couldn’t make out what mechanical structure is being used to have this type of motion. Can anyone please help.
Here’s a start:
There r 2 motors attached in the centre part of the robot, which keeps sliding back anf forth.
But, I can’t figure out out is the motor shaft being coupled to the structure, and how does it have tht kinda motion.
The sliding motion looks to be from a belt or chain. Utilizing a stepper motor with a chain or belt would allow you to count how many steps it takes to move a fixed point on the chain from one end of the track to the other. The fixed point on the chain or belt is attached to a pivoting mechanism (probably another stepper motor) within the body of the robot... inside the track that it slides on is probably a wire ribbon similar to that of the inside of a printer which would power the motors for the wheels. That's just me dissecting it with my eyes though.
OR... if you don't want to use a chain or belt, you can make a rack and pinion design to create the sliding motion.
thnx
i can't see any motors attached to da wheels, r thr motors?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
