Estimating the damping coefficient of a wave assuming a very small ratio
loto
The original problem is determining the dispersion relation of an ordinary wave in plasma damped by collisions. That part was easy enough but the next part is to find the damping rate (-Im(ω)) of the wave, assuming k is real and \nu << \omega where \nu is the collision frequency.
I've found the dispersion relation to be:
\omega^2 - k^2c^2 = \frac{\omega_{pe}^2(1-i\frac{\nu}{\omega})}{(1 + \frac{\nu^2}{\omega^2})}
And we are told the damping rate is:
\gamma = \frac{\omega_{pe}^2\nu}{\omega^2 2}
Since we want only the negative of the imaginary part:
\gamma = \frac{\nu\omega_{pe}^2}{\omega^2 (1+\frac{\nu^2}{\omega^2 })}
However, I can't think of an approximation that would give me that factor of 1/2. Series expansion or small number approximations don't seem to do it. If anyone has ideas, I'd just like a push in the right direction?
Apologies if this is irrelevant, but some people write the equation for damped oscillations as
\ddot x + b\omega \dot x + \omega^2 x = 0
and other people write it as
\ddot x + 2 b\omega \dot x + \omega^2 x = 0
I deliberately wrote b in those equations rather than the usual greek letters, because I don't know what notation convention is used in plasma dynamics!
Assuming you got the first part of the question right, is that where your factor of 2 has come from?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
