Volume of air from psi and diameter of pipe?
To determine the volume of air discharged at 40 psi through a 0.5-inch diameter pipe, the user considers using the velocity formula and the density of air at 70°F. They calculate approximately 32 ft³ in US units and 5.14 m³ (181.67 ft³) in SI units but are uncertain about their unit conversions. Another participant suggests using the standard pressure-volume-temperature (p-v-t) relationships to find a known volume of gas released under different conditions. The user questions how to establish a known volume and whether to use the regulator's maximum capacity, while also considering the initial and final pressure conditions. The discussion emphasizes the complexities of calculating air volume in compressed systems and the potential for simpler methods.
cpasc123
I need to find the volume of air (ft^3) for this sample. The air is discharged at 40 psi for 1 minute and the diameter of the pipe is 0.5 inches (Area = 0.001363538 ft^2). I think I need to solve for the velocity of the air (vel = sqrt(2P/rho), where P is the pressure and rho is the density). For the density I will assume the air is at 70°F and atmospheric pressure, so the density will be 0.074887 lbm/ft^3. I think I keep messing up with my units so I am not sure if I have the right answer or not. In US units I get about 32 ft^3 (I may be using the gravitational constant incorrectly). In SI units I get about 5.14 m^3 (181.67 ft^3). I am not really sure what I can expect for the volume of air, for air being discharged at 40 psi for 1 minute through a 0.5 inch diameter pipe. Any help would be greatly appreciated. Thank you.
aWhy not just use the standart 'p-v-t' relationships??
in one second, yoiu have a known volume of gas at a known temperature and pressure.
That volume is then released to occupy a much larger (unknown) volume at a different pressure-volume-temperature condition...
simple calculations ought to give you X ft^3 per unit time
Hopefully this might give you 'enough' of an acceptable answer.
Let me give you a little bit more information of the background. This is a large compressed air system. The samples are to be taken at several use points. Each use point has it owns regulator, which during the sample taking process is set to 40 psi.
So how would I have a known volume? Would I get that from the max volume capacity of the regulator (I don't think that would be correct)? If I were to use the p-v-t relationship would my initial pressure be 40 psi and my final be atmospheric? I would imagine the temperature would not change too much, but I don't know for sure and I would not be able to measure the initial temperature of the air in the compressed air system.
Why can't I just solve for the velocity of the air, which would seem to be a lot simpler?
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
