Polytropic exponent, thermodynamics question
The discussion revolves around calculating the polytropic exponent for air compressed in a diesel engine from an initial pressure of 1 bar to a final pressure of 41 bar, with its volume reduced to 6% of the initial. Participants clarify that the equation PV^λ = constant can be used, but emphasize the need to define initial and final volumes accurately. There is debate about whether to assume the process is adiabatic and how that affects the polytropic exponent, with references to heat transfer implications. The conversation highlights the importance of understanding the relationships between pressure, volume, and temperature in thermodynamic processes. Overall, the thread provides insights into solving thermodynamic problems involving polytropic processes and heat transfer considerations.
Studious_stud
Air is compressed to 6% of its initial volume in the cylinder of a diesel engine. In the process, its pressure increased from 1 bar to 41 bar.
Calculate the polytropic exponent for this process and comment on the associated heat transfer.
PV^λ = constant
Pinital (Vinital)^λ = Pfinal(Vfinal)^λ
Pinitial = 1 bar
P final = 41 bar
V initial = 100%
V final = 94%
Well I'm pretty much not sure if I'm going about solving this (probably simple) problem in the right way. Anyone care to help?
Also do you have to change the units from bar to pascals?
Thanks dudes and dudettes
Whew! "Polytropic exponent!" Ya live & you learn!
OK, so you know p1 and V1, giving you one equation with unknowns C and n:
p1V1^n = C
Then, what are p2(p1) and V2(V1)? Write the equation involving pp2 and V2 in therms of p1 and V1. That's a second equation with two unknowns C and n.
Solve pre h.s. algebra.
Now for part 2: if you assume an ideal gas, you can compute T1 and T2 (assume w.l.o.g. 1 mole of air), use the 1st law to express ΔU = (const.)ΔT, then work = ∫pdV and finally ΔQ = ΔU + W.
p1V1^n = C
Then, what is p2(p1
I don't quite understand, do I know V1? :S
No volume is given in the question but can you just use percentage values instead?
So I'll have
P1V1^n = C
and
P2V2^n = C
Thanks by the way rude man!
Hi Studios,
Pinitial = 1 bar
P final = 41 bar
V initial = 100%
V final = 94%
You have the right equation to solve for the polytropic exponent, but you need to better define Vi and Vf. If "Air is compressed to 6% of its initial volume..." then can you write a very short equation that relates Vi and Vf? Something like Vi = Vf C where C is a constant? Once you do that, you can find initial and final conditions so you can solve for the polytropic exponent.
Do you know how the polytropic exponent varies depending on heat flux? For an adiabatic (no heat transfer) process, the process is isentropic, so what do you think the polytropic exponent would be equal to in that case? For the case where temperature is constant, PV = mRT = constant, right? In that case, what would be the polytropic exponent and how would you describe the heat transfer to the air during the process?
Sorry, my post was totally incomplete.
Q Goest is giving you good leads.
One thing that bothers me is I think we're all assuming an adiabatic process, which was not given but maybe was so defined in the relevant chapter of the textbook. I believe that assumption is generally made, so maybe I'm just being picky. For that matter we weren't given authority to assumean ideal gas either - but what can one accomplish without that?
I suppose if n computes to cp/cv for air then we're entitled to assume isentropy.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
11K
10K
