Blocks being pulled by a string
  • Thread starter Thread starter alexialight
    Blocks String
The discussion focuses on a physics problem involving three identical blocks connected by strings and being pulled by a force F on a frictionless surface. The key points include determining the tension T in the string between blocks B and C and calculating the acceleration of the system. The relationship established shows that the total force F equals 3/2 times the tension T. Additionally, the acceleration of the entire system is derived as F divided by 3m. The participants confirm the calculations and clarify the relationships between force, tension, and acceleration.
alexialight
I'm just starting to get my head around the concepts of Tension and Force but I'm stuck on this question, I was wondering if anyone could help me out?
Q: 3 identical blocks connected by ideal strings are being pulled along a horizontal frictionless surface by a horizontal force F. The magnitude of the tension in the string between blocks B and C is T. Assume that each block has mass m.
i> What is the magnitude of the force? (Expressed in terms of T)
ii> What is the magnitude of the accleration of the three blocks (in terms of m and F)?
I worked out the acceleration on block B (T/(2*m)) but don't know what to do next. I'd really appreciate any help with this.
The acceleration is the same for the entire system. So the force must be (m1 + m2 + m3)*a
hope that helps
I think it does... that would make the Force 3/2*T right?
So in terms of m and F, the acceleration would be F/3m ?
Yes, you are right.
F - T = m_ca,
or
F = T + m_ca = T + m(\frac{T}{2m}) = \frac{3}{2}T
Awesome - Thanks a lot
