Calculating Stress Area at Hole Edge of Tube & Rod
  • Thread starter Thread starter pmlapl
    Area Edge Hole
To calculate the stress area at the edge of a tube with a rod inserted and secured by a pin, consider both axial tensile stress and bearing stresses on the tube wall at the pin location. The axial tensile stress is determined by the tube's cross-sectional area, while the bearing stress is calculated by dividing the force on the wall at the pin by the product of the pin diameter and wall thickness. It's important to account for the non-uniform distribution of force, which is highest along the axis of the applied force and zero normal to it. Additionally, shear tearout at the hole should be evaluated, assuming the pin diameter is small compared to the tube diameter. Understanding these factors is crucial for accurate design and analysis.
pmlapl
I have a tube with a rod inserted into it at a set depth. The rod is held in place by a round pin that passes through a hole in the side of the tube and into the rod. Assuming the pin and hole are the same diameter or very close, I'd like to know how to calculate the stress area on the edge of the tube when a force is applied to the end of the rod when the tube is anchored. I know that the force exerted by the pin is highest along the axis of the force and zero normal to it. So the force involved is not equal over the diameter of the pin which I'm puzzled about. Thanks for the help.
Actual stress distribution is quite complex, but for purposes of design, analysis can be simplified. In addition to axial tensile stress, a function of the tube cross section area, there are bearing stresses on the wall at the pin, which is the force
on the wall at the pin divided by ( pin diameter *wall thickness). Also check shear tearout at the hole. Assumption is that pin diameter is small relative to tube diameter.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
