Kinetic energy, movement <-> energy ?
Kinetic energy is defined as the energy an object possesses due to its motion. When a person kicks a ball, they exert a force over a distance, transferring energy to the ball, which then moves. This process illustrates that energy is imparted to the ball through the action of kicking, resulting in the ball gaining kinetic energy. The confusion arises from the phrasing in the book, which suggests that movement itself provides energy, but in reality, it is the force applied that converts potential energy into kinetic energy, enabling the ball to move.
miibay
Hi there,
I always thought that kinetic energy was the energy associated to a movement, ie, I have a ball in movement so I had printed the energy of my body on it when I kicked the ball, right? So I gave energy to the ball that started to move it. energy -> movement.
However, I was reading the book 'Principles of Chemistry' and in its definition of Kinetic energy they have 'energy given to a body by its movement', which according to my understanding means that I gave the energy to the ball when I kicked it and then the ball started to move, so movement -> energy.
Please help me! I'm so confused!
Thank you all in advance :)
Chemistry news on Phys.org
A body in motion has kinetic energy. (See: Kinetic Energy)
When you kicked the ball, you exerted a force on the ball through a certain distance, which resulted in the ball gaining kinetic energy.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
