Optimizing Power Supplies for Radio Telescope Projects
The discussion focuses on optimizing power supplies for a radio telescope project, specifically addressing two main questions. The first involves using an LM317 to regulate voltage between 13V and 18V while maintaining a current limit of 200 mA, with suggestions to either clamp the voltage or set the LM317 to deliver the desired current. The second question pertains to merging a regulated 5V supply with the 18V output, where daisy-chaining the regulators is proposed to reduce power dissipation. Calculations confirm that the thermal resistance and power dissipation for both regulators are manageable, suggesting that a simpler solution might be to use a dedicated regulated 18V wall wart. Additionally, the user realizes that using 9V batteries instead of AA batteries significantly impacts battery life, highlighting the importance of following design specifications.
mishima
Hi, I have two questions about power supplies. I am just curious of what is practical and possible.
i) I have been using a 30V wall wart regulated to 18V for a radio telescope project (using LM317). The load does not really need a set 18V, and could actually swing between 13V and 18V. The current on the other hand should stay close to 200 mA. Is there a way to limit current to this value while allowing voltage to swing through or be within that range?
ii) In the same project another part of the circuit requires a regulated 5V supply. I was curious what might be the best way to merge the two so that I only have one single plug. The way I understand things, simply using the 30V for both regulators would cause a huge power dissipation on the 5V regulator especially.
i) The LM317 can be configured as a current regulator. Do you need to clamp the voltage between 13V and 18V to prevent damage to the device? If not, just set the LM317 to deliver 200mA and you're done. If you need clamping then we can come up with something.
ii) Yes, 30V - 5V is a large voltage drop. I don't know you're current requirements for the 5V supply but the watts will add up quickly.
The LM317 is an LDO (Linear drop-out regulator). Those types of regulators do internal switching. That means the power dissipation is internal too.
You can get a switching controller to make a power supply. They use an external transistor, a coil, and a capacitor to do the bucking. The coil will do most of the dissipation and it can handle it. Here's one you can look at.
If your current requirements for the 5V are low enough you can still use a simple LDO. Your data sheet can tell you how to calculate the limit.
Texas Instruments makes an LM317. I'll give you a hint, always go with TI if you can. Their documentation is head and shoulders above other brands. The data sheets have clear explanations and plenty of design examples. They're written in proper english too.
I tried measuring current from both power supplies with a brand new load (suspected the older one was damaged). Now I am thinking maybe (i) is not a concern. It seems that with everything setup and a strong signal source directly in front of the dish the current being drawn from the regulated 18V is only 180 mA. This matches what I was originally expecting just by looking online about LNBs (most require ~200 mA). The fact I was getting 700mA to a full 1A earlier probably just meant that something in the old device was damaged.
As for the the regulated 5V supply and the chopper circuit, with everything setup and functioning properly I get 5mA drawn. With a strong signal source directly in front of the dish it comes up to 6mA.
So, its
30V->regulated to 18V needs 180mA and
8V-> regulated to 5V needs 6 mA
I want to turn into a single supply. Thanks for bearing with me as I plod through this. I will check the datasheet to see if the 5V current is low enough, I am pretty sure I know what you mean. Those calculations are what I need to do right now.
Daisy chain the regulators - pull your 5V from your 18V. Still a big drop, but better than 30 to 5.
6mA @ (18V-5V) = 0.078W
Even if the thermal resistance of your LM317 is high (~ 50C/W) you'll only get a temperature increase of 3.9C. Seems like you'll be ok. Just need to find the thermal resistance and maximum temperature in your datasheet to be sure.
Your formula should be something like:
(power dissipation)x(thermal resistance to air) + ( ambient temperature )< (maximum junction temperature)
For ambient temperature, military grade is 70C. That means it can work in extremely hot environments. You can go lower for industrial or commercial grade.
The maximum junction temperature is probably either 125C or 150C. It's a result of the manufacturing process.
Thermal resistance to air may be split up in your datasheet. It could be (die-to-case)+(case-to-air) or something along those lines. I hope that helps because not all datasheets explain the thermal calculations.
Well from the TI datasheet it is:
(thermal resistance junction to ambient) must be less than [(125-ambient temperature) / power dissipation]
From the STMicroelectronis datasheet, my values are
50 < (125-40) / 0.078 (seems unlikely I will be using at above 40 C)
50 < ~1090 (true)
For my 18V regulator on the other hand, its
(125-40) / 2.16 = ~40 which is not greater than 50. So its a good thing I've been using that heat sink there. :)
I think for simplicity's sake I may just break down and buy an actual regulated 18V wall wart. I already have a 5V regulator circuit soldered together anyways, and it doesn't need a heatsink. Then I could just totally eliminate the other regulator circuit (its a handheld type of thing, so less bulk is good).
I also think I found out why when I was using batteries they were draining so fast, yet no one else ever mentioned this problem. The design suggests 1.5 AA batteries, but I was using 2 9Vs in series. This website claims that at 200mA a 9V can only maintain 80% voltage for 1 hour. 1.5 AA batteries are eight times that! I had no idea there was that much of a difference. If I had used AAs, I could go from fresh batteries to 13V (still operational) in 35 hours (compared to a lousy 2 hours for 9Vs!). So that's what I get for not following instructions it seems.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
