Understanding Rotor RMF in Squirrel Cage & Slip Ring Induction Motors
The discussion centers on the presence of rotor rotating magnetic field (R-RMF) in squirrel cage induction motors (SCIM) compared to slip ring induction motors (SRIM). In SRIM, the three-phase supply to the stator generates an RMF that induces current in the rotor winding, creating its own RMF that is stationary relative to the stator. In contrast, SCIM relies on short-circuited rotor bars and end rings, which do not have a three-phase winding, raising questions about how R-RMF is generated in this design. While both motor types operate on similar principles, the mechanisms of RMF generation differ significantly. Understanding these differences is crucial for grasping the operational characteristics of each motor type.
nik235
is the rotor rotating magnetic field(R-RMF) present in squirrel cage induction motor (SCIM).
Is it same as in 3 phase ROTOR winding of slip ring induction motor (SRIM), generating rotor RMF.
* THE 3 phase, supply given to stator 3 phase winding of SRIM, generates (RMF), which cuts the rotor 3 phase winding of SRIM, now this flux cutting action results in emf induction and thus current flow in 3 phase rotor winding of SRIM, due to current, the rotor winding generates its own RMF, this RMF is stationery with respect to stator RMF, thus torque production.
so now, is the above described pattern same in SCIM too, if yes, then how is ROTOR RMF generated, with just rotor bars short circuited with end rings (ie in absence of 3 phase rotor winding).
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
