Step input to loaded transformer
  • Thread starter Thread starter Ambforc
    Input Transformer
The discussion focuses on calculating the response of a loaded ideal transformer to a step input voltage applied to the primary coil while a resistor is connected across the secondary coil. It is established that with the secondary coil disconnected, the primary coil exhibits a first-order response in current. However, when the resistor is placed on the secondary, the equations derived do not provide insight into the transient response of the primary current, simplifying to a standard DC circuit scenario. Participants suggest that for analyzing whole cycles, a transformer equivalent circuit should be used, while instantaneous DC values require solving Maxwell's Equations, as traditional circuit analysis is insufficient. The conversation highlights the complexities involved in transformer response modeling under specific conditions.
Ambforc
I am trying to calculate the response of a loaded ideal transformer to a step input. For example a step input in voltage from zero on the primary coil with a resistor connected across the secondary coil.
I already understand that with the second coil disconnected (for all practical purposes not existing) and the resistor connected in series with the voltage source over the primary coil a first order response in primary coil current will be observed. Now I am trying to simulate the response when the resistor is placed over the secondary coil. Of course, with no resistor over either the primary coil and the second disconnected you get an unbounded response in current (pure integrator).
The ideal assumption includes no resistance losses in any part except the load on the secondary coil and the ability to pass infinite magnetic flux.
This is as far as I have come:
Assuming the inductance of both coils to be equal with perfect coupling:
V_{1} = L \left(\frac{di_{1}}{dt} - \frac{di_{2}}{dt} \right)
V_{2} = L \left(\frac{di_{2}}{dt} - \frac{di_{1}}{dt} \right)
V_{2} = i_{2}R_{2}
However this set of equations reduce to:
V_{1} = -i_{2}R_{2}
and therefore fails to say anything about the transient response of the current in the primary coil i_{1} and appears to reduce to a normal DC circuit.
Any help will be appreciated.
Your problem statement is unclear. If you want answers for an integer number of whole cycles, use the transformer equivalent circuit.
If you want instantaneous DC values, then you must solve Maxwells Equations. Circuit analysis is inadequate for that case.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
