Turning a model car with no steering.
To turn a model car without steering, each wheel can be controlled independently using servos. Cutting power to the front left wheel while reducing the speed of the rear wheels can create a pivot effect for turning left. Alternatively, cutting power to the entire left side may also achieve the desired turn. Utilizing a skid-steer approach with different wheel speeds can effectively steer the vehicle. Implementing omni wheels can further reduce tire wear and eliminate the need for traditional steering mechanisms.
kpket
Hi Guys,
If I were to build a model car, with each wheel having it's own servo, then how can I make it turn in one direction.
Say if I want to turn left, if I cut power to the front left and reduce the speed of the rare wheels will the front left wheel act as a pivot? Or should I cut power of the whole left side?
Is there anyway I can simulate this?
Cheers
Kris
Welcome to PF.
The skid steer loader has 4WD without directional wheel steering. The best geometry to use is a wide vehicle with a short wheelbase as that reduces tyre wear while turning.
http://en.wikipedia.org/wiki/Skid-steer_loader
Different speeds for each wheel will steer the car.
Omni wheels will completely eliminate wear from lateral motion without the need for a conventional differential or accommodations for Ackerman steering geometry.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
