What is the difference between digital controls and digital control systems?
Digital control systems involve quantized systems and utilize the z-transform instead of the Laplace transform, distinguishing them from standard analog control theory. While there are mathematical and theoretical differences, practical applications often show minimal distinction as long as signals are sampled adequately. The discussion highlights that the terminology can sometimes create confusion, but the core principles remain consistent across both domains. Understanding the discrete-time domain is crucial, especially when stability issues arise. Overall, the participant's experience aligns with digital control concepts despite initial misconceptions about terminology.
timthereaper
"Digital" Control Systems
I recently took a control theory class at my local university and we learned about PID, loopshaping, and state-space methods and implemented them in MATLAB/Simulink and used an Arduino for some projects. However, I was talking with some EEs (I'm an ME) and they were mentioning a "digital controls" class. Is there a difference between "digital controls" and what I was doing? I figured since we weren't doing things with analog components directly, I was doing digital control systems. Am I wrong?
You're not wrong. What separates "digital" control theory from standard or "analog" control theory is that in digital control theory the system is quantized. This means you have to use the z-transform instead of the Laplace transform and there are some subtle stability gotchas due to the mapping from the continuous-time Laplace domain to the discrete Z domain. There are some differences mathematically and theoretically but in most practical cases the difference isn't much.
For the most part as long as you sample the appropriate signals fast enough you won't run into trouble but if things get weird it can be helpful to remember you're in a discrete-time domain.
Okay. That's good to know. We did have to use the Z-transform, so I guess I was doing digital all along. It's just weird because they mentioned it as if what I was doing was different.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
