Conservation of momentum without Newton's third law
Newton's third law is challenged by the principles of relativity, particularly in the context of electromagnetic interactions. Momentum conservation can still be upheld by adopting field theories, which replace action-at-a-distance concepts with fields that transmit forces between particles. In electromagnetism, both electric and magnetic fields carry momentum, defined as momentum density per unit volume. The total momentum of a system includes both the mechanical momenta of particles and the integral of electromagnetic momentum density. While the conservation of total momentum can be demonstrated, it requires complex mathematics, specifically vector calculus, to fully prove.
davidbenari
So I've recently read Newton's third law violates the principles of relativity. I only know how to prove conservation of momentum if Newton's third law holds. I was hoping someone could explain to me this (proving conservation of momentum when Newton's third law is false) without using extremely hefty mathematics, and specifically addressing E&M:
" It turns out that we can ``rescue'' momentum conservation by abandoning action at a distance theories, and instead adopting so-called field theories in which there is a medium, called a field, which transmits the force from one particle to another. In electromagnetism there are, in fact, two fields--the electric field, and the magnetic field." source: http://farside.ph.utexas.edu/teaching/em/lectures/node28.html#e311Thanks.
Science news on Phys.org
In a nutshell, the electromagnetic field carries momentum. We define this in terms of a momentum density (momentum per unit volume), as defined at the top of this page:
http://farside.ph.utexas.edu/teaching/em/lectures/node91.html
The total momentum of a system of particles and electromagnetic fields is the sum of the mechanical momenta of the particles plus the integral of the electromagnetic momentum density over all space. Momentum can be transferred between these two forms by way of the electromagnetic (Lorentz) force ##\vec F = q(\vec E + \vec v \times \vec B)##, but the total is conserved. Unfortunately, to prove that the total is conserved, you need to use a lot of "hefty mathematics" in the form of vector calculus.
Likes 1 person
