Steel Strength Chart | A36 Square Tubing Tension Strengths
  • Thread starter Thread starter ctstaas
    Steel Strength
A36 square tubing is commonly discussed for its tension strength, but it is not typically recommended for strength-critical applications due to its inferior material properties compared to stronger steel alloys. Users are advised to consult catalogs from various suppliers for detailed strength charts, including yield strength values. The MIL-HDBK-5J is a valuable resource for material properties, although it does not cover A36 specifically. It's crucial to ensure that the steel used is certified for the required strength, especially in safety-critical applications. Proper material selection is essential for any design where strength is a concern.
ctstaas
Hi All, I am looking for a chart with A36 square tubing strengths. I am mostly concerned with tension strength but yield and other values might come in handy later. Thanks for you input, Chris
Have you tried google? You can find catalogs from various suppliers of steel tubing if you take a little time to search for them.
You need to ask your supplier to ensure that you use the correct yield strength, as not all grades of steel are equal e.g. S275, S355, S420 etc where 275 is the yield strength in MPa or N/mm2
I've found MIL-HDBK-5J to be an excellent material properties resource that can be found free in PDF form online. That being said, A36 isn't covered in it because A36 typically isn't used in strength-critical applications dues to its material properties compared to other much stronger steel alloys being available.
http://www.everyspec.com/MIL-HDBK/MIL-HDBK-0001-0099/MIL_HDBK_5J_139/
If you have an application where material strength is a design concern, make sure to buy material which has been certified for the strength your design requires. This goes double for safety-critical applications.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
