Need help for electromagnetic repulsion device
The discussion focuses on developing a device that uses sound to open plasticized molds by creating vibrations or pressure. The creator is seeking advice on whether to calculate sound pressure or explore other methods for their electromagnetic repulsion concept. They are considering the use of AC electromagnets to repel a lid from an aluminum mold, questioning whether to use a single magnet or two opposing ones. It is noted that since aluminum is non-ferrous, eddy current forces may be necessary for effective operation. The conversation emphasizes the importance of researching eddy currents for further insights.
thomas blair
creating force with sound
Hi, I am currently building a device for the company I work for to open molds that have been plasticized together using sound. The idea is to produce a frequency that will either vibrate the lid open or push it open, but I am stumped on what calculations I need to use. Should I be calculating sound pressure or should I use some other means?
I would greatly appreciate some help!
Thomas
I should add the sound will be directed down a small hole into the hollow product inside the mold and I'm assuming that will create more pressure when the sound travels back to the lid
I am trying to figure out how my idea will work for an electromagnetic device that if possible would repel a lid from an aluminium mold that is 6in in diameter and 52in long and 1in thick would I be have to place an AC electromagnet on the opposite end of the lid while running a weaker current to the lid itself or would I need two opposing electromagnets at either end?
and the mold is in a cylindrical shape
Since aluminum is non-ferrous, you will need to use eddy current forces to do this. They are used in recyclable material sorting, for example. Let us know what you find with those Google search terms... :smile:
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
