A 0.18m long metal rod is places on some metal rollers in a megnetic
  • Thread starter Thread starter mnishi96
    Metal Rod
To calculate the voltage across the resistor in the given scenario, the formula V = IR can be used, where I is the current (0.034 A) and R is the resistance (25 Ω), resulting in a voltage of 0.85 V. To find the magnetic field strength (B), the formula F = BIL can be applied, where F is the force acting on the rod. The weight force can be used to find the force, which is 9.8 N. It's recommended to post such questions in the homework subforum for more targeted assistance.
mnishi96
A 0.18m long metal rod is places on some metal rollers in a megnetic field directed into the page. When the rod is moved left with a speed of 1.6ms-1, a current of 0.034 A is measured through the 25Ω resistor.
How would I calculate the voltage when I'm not given the magnetic field strength? V=BvL
help please!
To find B can I use F=BIL?? and for force I use 9.8(weight force)
Welcome to PF!
This appears to be a homework or homework-type question and should be posted in the homework subforum. Doing so will ensure you get the appropriate help from our outstanding staff of homework helpers. (instead of wikipedia surfing armchair scientists like myself)
Thanks!
Likes 1 person
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
