A block of mass going down an incline plane with friction
The discussion focuses on a physics problem involving a 15.0 kg block sliding down a 45-degree incline and then traveling on a flat surface with friction. Participants emphasize the need to apply Newton's Laws of motion to determine the block's acceleration on both the incline and flat surface. The coefficient of kinetic friction is given as 0.200, which affects the block's motion after it reaches the flat area. Suggestions include using conservation of energy principles and kinematic equations to solve for the distance traveled on the flat surface before coming to rest. The conversation highlights the importance of breaking down forces into components to accurately calculate the net force and subsequent acceleration.
chiCEstudent
A block of mass m = 15.0kg starts from rest and slides down an incline plane with slope angle theta = 45 degrees for a distance d1. It then reaches the flat surface and travels for a distance d2, where it comes to rest. The coefficient of kinetic friction between the block and all surfaces is the same everywhere with a value of uk = 0.200
Write the Newton's Laws equations of motion and solve for acceleration of the block on the incline plane. Do the same for the block's motion on the flat region. (the question also asks for free body diagrams but I know how to do this)
Given d1 = 2 meters, find d2, the distance the block travels on the flat surface before coming to a rest.
Newton's Laws equations? This is the part I don't know
I am not sure what equations I need to use...
Thanks for the help in advance! If anyone can provide the equations I think I can take it from there... thanks!
Try conservation of energy
For a conservative force, 0=W_{net}={\Delta}U+{\Delta}K+F_ks,
where {\Delta}U=mgh_f-mgh_i and {\Delta}K=\frac{mv_f^2}{2}-\frac{mv_0^2}{2}. F_ks is the force of kinetic friction times the displacement.
You should then be able to use that and constant acceleration equations to solve the problem.
Ok... I am trying the equations, but I'm not sure which values to plug in where. I know gravity has a -9.8m/s2 acceleration, but I don't think this value applies since its on an incline of 45 degrees. I remember something about finding the vector components using sine and cosine... If someone can give me another push in the right direction I would really appreciate it
Fnet=ma
The block is moving down the ramp with a constant acceleration because of gravity and friction(draw a picture of the forces to find the net force and therefore the acceleration). When it reaches the flat part it has constant acceleration based only upon friction.
You can use kinematics equations to find the speeds and distances once you find the acceleration.
