A bushranger hanging out of a hotel window
  • Thread starter Thread starter PG222
    Window
A bushranger aims to drop from a hotel window onto a horse moving at 14.0 m/s, with the saddle 2.50 m below. The time in the air was calculated to be approximately 0.714 seconds. However, the calculations lacked clarity, particularly for the horizontal distance needed for the drop. Kinematic equations are recommended for solving the problem, especially if air resistance is ignored. The discussion emphasizes the importance of providing reasoning and thorough calculations in physics problems.
PG222
A bushranger hanging out of a hotel window wishes to drop vertically onto a horse galloping under the window. The constant speed of the horse is 14.0 m/s, and the distance from the window to the level of the saddle is 2.50 m.
(a) What must be the horizontal distance between the saddle and window sill when the bushranger makes his move?
(b) For what time interval is he in the air?
I'm not too sure of what equations I was meant to use but I tried this:
X=-2.5
X=0.5(-9.8)t^2
D=Ut
Using the above equations I worked t out to be 0.714 seconds
And for the horizontal distance I ended up with 10 meters
Welcome to PF;
Was there a question in all that?
some things stand out:
1. you have not provided the reasoning for your working
2. you have not done anything for part (a)
3. would "distance" be the magnitude of the displacement here?
Kinematic equations would be appropriate here - especially if you want to neglect air resistance.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
